Re: Farmall 1206D hydraulic pressure problem
Posted by John M on November 13, 2001 at 17:38:43 from (64.6.3.36):
In Reply to: Farmall 1206D hydraulic pressure problem posted by Scott Houtex on November 13, 2001 at 09:46:01:
Theres no good way to check relief valve other than replace it.$$$. There is an o-ring & backup ring in bore of housing that can be seen after valve is removed that may be bad. Also, oring (somtimes teflon seal ring) between hyd pump mtg plate & trans hsg can blow. (common) To check, remove 3ard link bracket,start tractor & pull remote lever & watch for turbulence of oil at pump area inside tractor.
Post A Followup
: Re: Re: Farmall 1206D hydraulic pressure problem
