Posted by Hugh MacKay on March 16, 2009 at 02:30:59 from (216.208.58.118):
In Reply to: Carburetor posted by Farmall Bob on March 15, 2009 at 19:59:07:
Bob: I'll give you a little tip on Carter Carbs, if you have one, drop it over a cliff. IH probably used a half dozen different Carter carbs on A, B, C, SA, etc. Today the aftermarket is trying to service all those carbs with two kits. While a lot of the parts are the same, some are only close. If you can make a Carter work properly, your a genius.
Zenith are some better, at least one can still get a kit for each carb, problem is the ID system on Zenith carbs is not great. If you get a patient parts man, patient enough to make sure kit is right, even I can make a Zenith work.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
