cooling system on a Super-A
Posted by John K on November 14, 2001 at 08:18:00 from (143.206.241.8):
I have a Super A that does not have a water pump. Earlier messages on this board suggest that there may have built up a lot of crud in the engine's water jacket over the years, that I could remove if I were to pull the sleeves. But is there a way to flush the crud out without tearing down the engine? Without a pump, would the A's siphon system be enough to flush out the build up?
Post A Followup
: Re: cooling system on a Super-A
