Re: 240 farmall
Posted by Moose on November 14, 2001 at 20:24:53 from (12.91.126.22):
In Reply to: 240 farmall posted by Dann on November 13, 2001 at 21:38:56:
I would strongly suggest you unsrew the bottom drain plug as well and check for water in the transmission. Condensation is a problem and I have seen some with a gallon or more of water. If the oil is milky, it should be drained and changed. You'll need a couple of five gallon buckets to slide under the rear.
Post A Followup
: Re: Re: 240 farmall
