Re: Hydralic pump help needed
Posted by Jon,NH on November 14, 2001 at 22:11:21 from (206.152.188.131):
In Reply to: Hydralic pump help needed posted by CCJ on November 14, 2001 at 05:30:58:
I need to ask a question,is this the hyd pump thats run your power steering or the rear hitch?If it is ,it needs to be primed.Your hyd lines which supply fluid to the pump,do they run along the right side of the tractor?Does one of these hyd lines definitely have a loop or a U -shape in it?
Post A Followup
: Re: Re: Hydralic pump help needed
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
