Re: 1256 hydraulic
Posted by the tractor vet on November 15, 2001 at 19:28:40 from (216.196.13.189):
In Reply to: 1256 hydraulic posted by BILL SMITH on November 15, 2001 at 12:19:25:
I have seen this problem on a lot of the 06 -56-66 seires tractors and the only thing that i have found is that the tractor is used for short period of time and then shut off and let set or that the breather is not doing it's job and allowing condenshion to build up in the transmission and rear end. Not all do it ,so check the fill tube to make sure that the breather is open and the trans dipstick sometimes it helps to drill another hole in the dipstick flange and also on the fill tube across from the hole .
Post A Followup
: Re: Re: 1256 hydraulic
