Re: 6 VOLT H WIRING
Posted by The Red on November 16, 2001 at 05:42:06 from (12.84.245.31):
In Reply to: 6 VOLT H WIRING posted by KIRK on November 16, 2001 at 04:55:28:
Kirk they were originally positive ground. After you hook up the battery, take a wire and momentarily touch the bat. terminal on the voltage regulator and the armature post on the generator to make a spark. That will polarize the generator. Then see if you are getting a charge. Make sure the points in the voltage regulator or cuttout are closing when the engine is running.
Post A Followup
: Re: Re: 6 VOLT H WIRING
