Re: Bush Hog / Implements for 1941 H
Posted by Tom W on November 16, 2001 at 14:23:19 from (166.94.90.148):
In Reply to: Bush Hog / Implements for 1941 H posted by Cary on November 16, 2001 at 13:12:47:
We have a 41 H and pulled a 7 ft bush hog with no problem. What you MUST have is a overrun PTO clutch. Your PTO size will be 1 1/8 and most PTO equipment need 1 3/8 shaft. You can buy a 1 1/8 to 1 3/8 overrun clutch for your tractor. Best place to fine one is at a Ford tractor store. All the old fords had a 1 1/8. If you don"t have the overrun clutch, the bush hog will act like a fly wheel and push you into a place you don't want to be.
Post A Followup
: Re: Re: Bush Hog / Implements for 1941 H
