Re: Firing
Posted by Glenn(WV) on November 16, 2001 at 21:19:18 from (67.201.149.212):
In Reply to: Firing posted by Tommy Thomas on November 16, 2001 at 20:03:00:
Pull off the distributor cap and crank the engine. If the distributor shaft isn't turning, then you may have a stripped distributor drive gear.
Post A Followup
: Re: Re: Firing
