Re: 40 Farmall A hood grille
Posted by gene b on November 17, 2001 at 03:29:36 from (63.15.137.15):
In Reply to: 40 Farmall A hood grille posted by Ralph Detwiler on November 16, 2001 at 19:30:10:
mmake sure when you find a grille you get the right one some early ones had one of the 1/4 turn screws way down under by the pedestal later this was moved to right below the crank opening it will be hard to find the early one i just sold an early one the later style can be used if you put the bracket on that supports at the crank opening I have one of those if you need it your radiator is also different because of the 1/4 screws glad to help
Post A Followup
: Re: Re: 40 Farmall A hood grille
