Re: Re: serial number of farmall regular
Posted by walt f on November 17, 2001 at 21:29:14 from (24.159.77.113):
In Reply to: Re: serial number of farmall regular posted by Glenn(WV) on November 17, 2001 at 19:53:42:
the serial # on the regulars i've seen, are in three places, the tool box, as mentioned before, the frame rail, left side,forward of the radiator, and the third place is on a raised pad on the left side of the engine block, like the f-20 but forward on the block, also the tool box serial # plate on a regular only has 2 rivets, one on each side, the f-20 has one on each of the four corners. the most acurate serial # will be the one on the left side, forward of the radiator.
Post A Followup
: Re: Re: Re: serial number of farmall regular
