Re: Farmall M Knock
Posted by El Toro on March 16, 2009 at 03:54:31 from (64.12.116.73):
In Reply to: Farmall M Knock posted by cessnapilot3@gmail.com on March 15, 2009 at 20:43:51:
To remove the crankshaft you would need to split the tractor. Your local auto machine shop can determine if the crankshaft can be saved by grinding it undersize. It may have already been ground undersize. The block needs to be dipped and cleaned of all metal particles. You should have it magna-fluxed for cracks and the head too.
If the local shop can ground the crank undersize have them furnish the correct bearings. If the block isn't cracked you should have new cam bearings installed. Some of the men that post on here have parts tractors, so you may be able to get a good block if its needed. Hal.
PS: Take a look at the clutch while the engine is off and see if the clutch disc is down to the rivets or getting close. Good time to have it relined if it is.
