Farmall Tractors Discussion Board
Re: Super C wiring ??????
Posted by Milan D. Radakovic on March 10, 1999 at 15:46:14:
In Reply to: Super C wiring ?????? posted by Michael Powell on March 08, 1999 at 18:31:29:
From my experience with 8 volt batteries, I would not recommend them. Your current charging system will not produce enough output to charge an 8 volt batttery, and I have never seen a charger that has an 8 volt setting. And a 12 volt setting will over-charge. I use a fully automatic onboard battery charger on my 6 volt battery that's on my Super C and never have anymore trouble with weak starts. The one I use is from Superior Motorcycle Products, Columbus, Ohio. It's called the "Superior Accu-Charger". I picked it up at Meijer's for $19.99. It's switchable for 6 and 12 volt. It has two wires, one for pos. and one for neg., and a connector that attaches to the charger, so it can be concealed under the battery box lid when not in use. Hope this helps you out....
Post a Followup
: Re: Re: Super C wiring ??????
