Re: 1950 Farmall M Fan Belt
Posted by Haas on November 19, 2001 at 07:30:48 from (129.37.117.10):
In Reply to: 1950 Farmall M Fan Belt posted by Chad Redding on November 18, 2001 at 15:05:22:
Chad, the fan belt pulley on the M is a split pulley. You adjust the belt tension by adjusting the width of the pulley to make the belt run lower or higher in the pulley. This is done with the threaded flange that you noticed on the front of the fan. The flange turns on threads to move the front half of the pulley in and out to adjust the belt tension. There is a set screw on the flange which also has a lock nut on it. The set screw holds the flange and keeps the tension. Locate the set screw, loosen the lock nut and then loosen the set screw. If the flange is like most of them, you are into a lot of penetrating oil and wire brushing to get the threads cleaned up to where you can rotate the flange. It's easier to work on if you take the radiator off, but of course if you do not need to have the radiator refurbished at a radiator shop, try to get the flange loose without taking things completely apart. Once the flange at the front of the fan is loose, you can loosen it until the belt is in the bottom of the pulley at which point it is loose enough to work off the engine pulley and then over the fan to remove it.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
