Re: H radiator removal/rod bearing size
Posted by Zonie on November 19, 2001 at 20:02:36 from (152.163.201.78):
In Reply to: H radiator removal/rod bearing size posted by Larry on November 18, 2001 at 20:10:28:
Larry,
You can not get to the rear main bearing or the rear main seal with out splitting the tractor.
If the oil pan has lots of sludge I'd recommend pulling the engine to have the block boiled out in a hot tank. other wise the sludge can ruin the new bearings and crank.
Just my 2 cents worth!
Post A Followup
: Re: Re: H radiator removal/rod bearing size
