Re: Re: Re: Farmall 340 value?
Posted by J.D. Humm on November 20, 2001 at 02:43:37 from (12.65.234.42):
In Reply to: Re: Re: Farmall 340 value? posted by Curt on November 20, 2001 at 00:26:28:
As far as the steering catching I have a 504 with a loader. The 504 is basically a souped up 340. I had to overhaul the steering gearbox. The seal had started leaking and let the big bearing go bad. I blamed the extra stress from the front end loader on a tricycle front end for creating the problem. I then put on a new Schwartz wide front end which transfers all the stress to the tractor frame rather than the gearbox. Good luck with your tractor and your restoration project.
Post A Followup
: Re: Re: Re: Re: Farmall 340 value?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
