Farmall Tractors Discussion Board
Re: 5140 won't pull
Posted by RickB. on March 10, 1999 at 17:59:52:
In Reply to: 5140 won't pull posted by Tim on March 09, 1999 at 18:21:42:
If you don't have a service manual for this tractor, do yourself a favor & get one now. There are several orfices & screens protecting the various valve spools that operate the trans. I would look in the area of the dump solenoid & spool, checking for voltage & pressure, then the F & R solenoids & valve spools. The dashboard will give you fault codes, learn how to retrieve & interpret them. I have been away from Maxxums for a couple of years now, so I can't quote chapter & verse, but without detailed service info, a good multimeter, and pressure gauges, you will be there forever. Don't overlook the importance of good clean grounds for the electrical circuits.
Post a Followup
: Re: Re: 5140 won't pull
