Re: AOS6 3 point linkage wont lift all the way up?
Posted by Redfan on November 21, 2001 at 11:58:57 from (203.87.49.4):
In Reply to: AOS6 3 point linkage wont lift all the way up? posted by David on November 20, 2001 at 22:25:01:
We had a 564, same setup, do a similiar thing once Dave, and found the seal on the lift piston was failing occasionally. Suspected something when the gear oil started leaking out the axle seals. Might be worth checking. Otherwise your pump is on the way out, which will be a problem because they're basically a throwaway pump. Hope it's some help. Regards, Redfan.
Where abouts you posting from Dave?
Post A Followup
: Re: Re: AOS6 3 point linkage wont lift all the way up?
