Re: 1586 manifold oil leak
Posted by the tractor vet on November 22, 2001 at 15:09:40 from (216.196.13.46):
In Reply to: 1586 manifold oil leak posted by Troy on November 21, 2001 at 19:01:29:
You did not say if it was only on one port or all ports if only on one the i would have the injectors tested if it is on all the check the turbo at the cross over pipe as far as to the ft seal well fix it it can be done buy removing the crank pulley then pull the oil pump and replace the seal since it is in the oil pump you don't have to pull the ft. end off the tractor it takes about and hour to and hour and a half to do it all and it is a good time to check the pump.
Post A Followup
: Re: Re: 1586 manifold oil leak
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
