Re: Unknown set of pistons rings and sleeves?????
Posted by George 2 on November 22, 2001 at 15:24:16 from (216.46.140.73):
In Reply to: Unknown set of pistons rings and sleeves????? posted by ZANE on November 21, 2001 at 04:03:43:
They are for a 300 tractor either Farmall or International utility type. The 300 has a 3 9/16 bore ie. 3.5625 on sleeve your size of 3.588 is close. The Farmall Super H was 3.500 ie too small to be the ones you have.
Post A Followup
: Re: Re: Unknown set of pistons rings and sleeves?????
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
