300U pressure plate adjustment
Posted by Robert on November 23, 2001 at 10:40:15 from (63.212.184.193):
Just split 300U for replacement of flywheel ring gear. Before I split the machine I noticed that the clutch pedal went down almost to the bottom of travel before it engaged (linkage has been adjusted}. I had looked through the bottom inspection cover and noticed that the pressure plate
fingers were quite a way from the front of the throw out bearing. Is there a specific height for the fingers? I see such a spec. for the TA clutch But not for the engine clutch.
Thanks.
Robert
Post A Followup
: Re: 300U pressure plate adjustment
