Re: Re: Stuck Sleeve
Posted by Larry on November 25, 2001 at 20:25:03 from (216.202.132.34):
In Reply to: Re: Stuck Sleeve posted by Farmer D on November 25, 2001 at 19:48:19:
Will try welding if all else fails. Would have to borrow a welder. Also a little concerned about slag flying everywhere. The block still has the crank..cam..etc in it and don't want little chunks of metal in there since I wasn't planning on taking block to shop. When you did the weld trick was your block stripped out at the time? Thanks
Post A Followup
: Re: Re: Re: Stuck Sleeve
