Re: Farmall B motor switch
Posted by gene b on November 26, 2001 at 04:20:50 from (63.25.166.121):
In Reply to: Farmall B motor switch posted by Brian on November 25, 2001 at 20:46:53:
there are a lot of them running around redo the steering sector and you can have live hy just add a spool valve and small resivour as the C has the live pump otherwise just block of the hole in the C block whil you are at this project I would take the back frost plug out and get all the rusty stuff out of the block this would be the one on the manifold side the plug behind the filter is for the camshaft i would also pull the pan and clean the oil sump
Post A Followup
: Re: Re: Farmall B motor switch
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
