Re: should I bother to haul this 300 U home?
Posted by big fred on November 26, 2001 at 07:01:51 from (12.13.226.14):
In Reply to: should I bother to haul this 300 U home? posted by Bruce (WA) on November 25, 2001 at 21:33:11:
I looked into the cost of a new hydraulic pump for mine about a year ago. Lowest price I found was about $550. I ended up being able to fix the problem with helicoils once I identified the problem. Definitely worth dragging home for $400, I would think. You won't want to run that thing with a loader and no power steering, though.
Post A Followup
: Re: Re: should I bother to haul this 300 U home?
