Re: 706 starter
Posted by Red Dave on November 26, 2001 at 09:58:47 from (208.165.46.34):
In Reply to: 706 starter posted by sven6 on November 26, 2001 at 09:37:33:
Sounds to me like either a bad main contact on the solenoid or a bad spot on the starter motor's commutator.
If you are a little bit handy, you can take the solenoid apart and clean up the contacts on the inside. Some of them had a disk for the moving contact that could be turned over to have a new surface. Or you could just get a new solenoid.
Make sure all your battery conections, solenoid & starter connections (including grounds) are clean, bright and tight.
If that doesn't fix it, you will have to take the starter to a shop that can test it for you.
Post A Followup
: Re: Re: 706 starter
Today's Featured Article - Memories of an IH Super A When I was ? up to 10, I worked on my Papaw's farm in Greeneville, TN every summer. As I grew older (7), it was the thrill of my day to ride or drive on the tractor. My Papaw had a 1954 IH Super A that he bought to replace a Cub. My Papaw raised "baccer" (tobacco) and corn with the Super A, but the fondest memory was of the sawmill. He owned a small sawmill for sawing "baccer" sticks. The Super A was the powerplant. When I was old enough (7 or 8), I would get up early and be dressed to ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
