Re: info on H ???
Posted by The Red. Nope! on November 26, 2001 at 10:15:53 from (206.246.187.2):
In Reply to: info on H ??? posted by sHan on November 26, 2001 at 10:09:30:
sHan that is a regular H with that aftermarket seat pedastal. That is not a diesel engine and the tractor is a standard H. With gasoline short during the war, many farmers had to use distillate (poor man's gas) to run the tractor. You started it on gas with the small tank. Once it was warmed up, you switched over to the distillate.
Post A Followup
: Re: Re: info on H ???
