Re: Super A trans. input shaft joint
Posted by Haas on November 27, 2001 at 05:45:22 from (129.37.117.121):
In Reply to: Super A trans. input shaft joint posted by Michael on November 26, 2001 at 20:01:15:
Like the "vet" says, find a case IH dealer. You can get the bolts and the rubber bushings. Also, the bolts are supposed to be tapered and fit in a tapered hole in the coupling. In case you were wondering. Usually they are wedged in real tight and hard to get out.
Post A Followup
: Re: Re: Super A trans. input shaft joint
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
