Re: I need fire!
Posted by John M on November 27, 2001 at 19:41:15 from (64.6.1.50):
In Reply to: I need fire! posted by AGR538 on November 27, 2001 at 15:15:32:
I`d get a 6v batt, check to make sure ign. switch is working,cap,rotor, plug\coil wires are OK, put in new points & hot plugs,(ch D21) then pull start it if necessary. Points, and not the coil, are usually the "culprit" when you have no spark.
Post A Followup
: Re: Re: I need fire!
