Re: weight of tires
Posted by Farmer Bob on November 27, 2001 at 21:39:17 from (66.152.73.65):
In Reply to: weight of tires posted by Dan on November 27, 2001 at 20:50:59:
Dan, Approx 150 lbs. ea with tire & rim. If loaded, would add another 475-600 lbs depending on the solution mixture.//FB
Post A Followup
: Re: Re: weight of tires
