Re: IHC 10-20 with air-tires
Posted by Will@on.ca on November 28, 2001 at 00:49:50 from (216.58.67.32):
In Reply to: IHC 10-20 with air-tires posted by Jens on November 27, 2001 at 11:47:00:
Jens,does your rims have two valve stems,one for air and one for fluid.From what I have learned about this switch from steel to rubber, if you look at the spokes on the rubber rims you can see that the steel rim was cut off and the rubber rim was welded on.I,am looking for a set of pistons for my 10-20 if anyone has any leads.!!Will
Post A Followup
: Re: Re: IHC 10-20 with air-tires
