Re: Re: Re: M coughs under load
Posted by Steven@nd on November 28, 2001 at 08:58:02 from (165.234.131.175):
In Reply to: Re: Re: M coughs under load posted by Moses on November 28, 2001 at 08:54:21:
Sometimes it can, the packing can deteriorate and then the screw can move, or else if it has a spring on it the spring can get weak. I usually have to adjust the screws on the carb of my Super MTA everytime I use it, not sure why but it could be temperature and the specific load I put on it.
Another thought is that maybe a rust particle or something plugged one of the passages in the carb.
Steven
Post A Followup
: Re: Re: Re: Re: M coughs under load
