Re: Farmall 400 D
Posted by Steven@nd on November 28, 2001 at 16:09:14 from (12.23.184.193):
In Reply to: Farmall 400 D posted by FM on November 28, 2001 at 15:10:32:
The 400 has the engine that starts on gas then switches to diesel once warmed up. Watch out for a cracked head! Check the oil in the injector pump, if it is way overfull or has diesel in it, the pump will need work - same with the crankcase oil. Expensive engine to repair, bearings are nearly impossible to find.
Steven
Post A Followup
: Re: Re: Farmall 400 D
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
