Re: TD-6 running poorly
Posted by brianh on November 29, 2001 at 05:09:33 from (205.188.192.39):
In Reply to: TD-6 running poorly posted by Tom Graham on November 28, 2001 at 19:20:39:
Are the fuel filters OK? Do you have the fuel pressure gauge on your pump, and does it read normally when the problem occurs? I have seen pumps that have excess internal leakage or a plugged up scavenging system fill up with fuel in the sump and then they run really bad. It would seem that if it runs OK most of the time that the injectors would probably be OK. Brian
Post A Followup
: Re: Re: TD-6 running poorly
