Re: Farmall H 5th gear flameout
Posted by CNKS on March 16, 2009 at 06:28:24 from (216.144.104.128):
In Reply to: Farmall H 5th gear flameout posted by Jim Isler on March 15, 2009 at 20:46:45:
That is normal, 5th is direct drive--no gear reduction. I have to "slip" the clutch, not good for the clutch, but I don't use 5th much. Starting in 4th to get it rolling and then shifting to 5th as Jim says helps. I have never tried to master double clutching. Going into 5th grinds more easily than the other gears, so you need to be careful.
