Re: Foaming Hydraulic Fluid in M
Posted by Haas on November 29, 2001 at 18:56:05 from (129.37.117.180):
In Reply to: Foaming Hydraulic Fluid in M posted by Farmer Bob on November 29, 2001 at 17:56:54:
If you are using the Lift All Belly pump, you should be using 30 wt NON DETERGENT oil. If you use detergent oil, it is likely to foam. You can also use HyTran, or other tractor fluid, but if you do, you are likely to generate less pressure, especially when things get hot and thus you will not be able to lift as much.
Post A Followup
: Re: Re: Foaming Hydraulic Fluid in M
