Re: Re: Foaming Hydraulic Fluid in M
Posted by Paul on November 29, 2001 at 21:45:42 from (216.7.36.11):
In Reply to: Re: Foaming Hydraulic Fluid in M posted by Steven@nd on November 29, 2001 at 18:20:24:
If your cylinder will not stay up you could have
a blown cylinder and so the oil will not stay full
on the other side of the ram. This will cause it
to cavitate and then more oil will return to the
reservoir and cause it to over flow. If you cant
get any down pressure with your loader it
could also be your spool valve has a crack or
is worn out and that could also cause the
cavitation of a cylinder. Paul
Post A Followup
: Re: Re: Re: Foaming Hydraulic Fluid in M
