Farmall Tractors Discussion Board
Re: Fluid in tires (Farmall H)
Posted by Phil Auten on March 11, 1999 at 18:49:01:
In Reply to: Fluid in tires (Farmall H) posted by jr on March 11, 1999 at 16:38:34:
jr,
Calcium Chloride is usually used in tires for
the weight. It weighs more than antifreeze/water
mix or windshield washer fluid. I suspect you'll
need around 50 gallons to fill each tire. If you
used a 50/50 mix of antifreeze it'll take 50 gal.
to do both tires, plus 50 gal. of water. It'd
take 100 gal. of the windshield stuff. Call an
ag tire dealer and ask how much to fill your
tires. I'd bet you come out ahead with the CaCl.
You might have to replace the tubes in your rears
if they don't hold air for long periods (a month
or more). If you do, while the tires are off,
clean and paint the insides of the rims with a
good quality zinc chromate primer and a couple of
coats of spray enamel (black is fine) to help keep
rust to a minimum.
Good luck,
Phil
Post a Followup
: Re: Re: Fluid in tires (Farmall H)
