Farmall Tractors Discussion Board
Re: Live Hyd Pump
Posted by Craig on March 11, 1999 at 19:21:33:
In Reply to: Live Hyd Pump posted by Lynn on March 11, 1999 at 16:58:49:
The only thing you can check is backlash in the gears, seal and bearings, I would put it on and see how it preforms. You must add a relief valve in the system or you can break the camshaft off the front of motor. Also if you have a M and not a Super M you will probably have to rework front cover and plate or replace them with Super M so pump will bolt up. There are a few late M's with the later front that won't require change.
Post a Followup
: Re: Re: Live Hyd Pump
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
