Farmall Tractors Discussion Board
Re: Live Hyd Pump
Posted by Craig on March 11, 1999 at 19:26:45:
In Reply to: Live Hyd Pump posted by Lynn on March 11, 1999 at 16:58:49:
The only thing you can check is backlash in the gears, seal and bearings, I would put it on and see how it preforms. You must add a relief valve in the system or you can break the camshaft off the front of motor. Also if you have a M and not a Super M you will probably have to rework front cover and plate or replace them with Super M so pump will bolt up. There are a few late M's with the later front that won't require change.
Post a Followup
: Re: Re: Live Hyd Pump
