Re: 560 Hyd problem
Posted by IH-NEAL on December 01, 2001 at 19:00:51 from (216.165.147.240):
In Reply to: 560 Hyd problem posted by Todd on December 01, 2001 at 16:01:44:
Todd, it appears as though you may have a problem with the followup linkage on your fast hitch. Their should be some linkage that hooks up to the rockshaft on the fast hitch, early had a cable, which should be now changed over to solid linkage setup. That should be on left side of cowl ahead of your feet. you will see it move when you adjust your hitch. If that is loose or binding it will cause the problem you describe. May just need a little freeing up or maybe adjusting. The other problem I will not try to explain because it becomes way to complicated for a layman. It would be related to the safety regulator valve. If you talk to a repairman at an IH dealer, he can explain it. I'am an old IH mechanic as you noticed I didn't mention Case-IH,brrr.
Post A Followup
: Re: Re: 560 Hyd problem
