Re: Re: Super C width
Posted by Ernie Bob on December 01, 2001 at 22:27:51 from (205.188.199.58):
In Reply to: Re: Super C width posted by Paul Shuler on November 30, 2001 at 20:41:52:
There are a couple of things to consider, first do you have the wider axel housing (there were 2 sizes of these), second do you have the wider axel shafts (there were 2 sizes of these also).
If you have the fast hitch it is very easy to move the wheels in. I put a 6x6 block of wood under each side of the fast hitch and use the down pressure to raise the rear wheels off the ground. With clean, lubed shafts the wheels move quite easily. By the way I have the narrow axel housing with the wide axle shafts and I have to n move the wheels all the way in to trailer it.
Post A Followup
: Re: Re: Re: Super C width
