Where are you putting shims inside the pump? My Lift-All manual doesn't mention shimming anything. If clearances are too great to produce good pressure, you need to replace worn out parts--either the pump body, cover plate, or back plate.
The drive gear and driven gear have to be "thinner" (1.998 in. to 2.000 in.)than the pump body is thick (2.001 in. to 2.003 in), or the pump cover and backplate will pinch the ends of the gears when you tighten the bolts.
The driven gear stud and the drive gear shaft keep the gears where they need to be in the pump body, if the bushings for the gears are all in good shape.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
