Re: Farmall M 1952
Posted by Dan on December 02, 2001 at 12:56:53 from (12.18.158.25):
In Reply to: Farmall M 1952 posted by John on December 02, 2001 at 05:48:23:
you are probably getting too much fuel. There is a hole plugged with a piece of felt to let the excess gas run out the bottom. I over hauled the carb on my SMTA about 6 times before I found out the camshaft was bad, the end had chipped off next to the keyway and the drive gear was loose. Result of lots of use of the live pump. Is your float set correctly and did you check for leaks? also if the lobes of the float get bent a bit they might not go up and down exactly right and might hang up. Same can happen if the shaft they pivot on gets warn. There are a bunch of little passages for air etc in the carb that must be clean. Don't clean with a cutting torch tip cleaner like I did though. Also make sure the throttle plate is in correctly. It will go in either right or upside down but or backwards but won't close right if it is in wrong. There is an idle passage on one side that is partially closed off when the throttle is closed. The service manual for the tractor has an excellent description of how things are supposed to work. Another thing is most of the time these trqctors seem to take little or no choke even in cold weather. If you are over choking it would make fuel run out too. Good luck on it. I know it can be really frustrating getting it worked out.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
