Posted by ScottyHOMEy on March 16, 2009 at 07:01:59 from (70.105.234.113):
In Reply to: Farmall M Knock posted by cessnapilot3@gmail.com on March 15, 2009 at 20:43:51:
Just to add my vote to the tally . . .
That knock isn't going to go away on it's own, especially if the rod bearing diagnosis is correct.
Best case is you open it up soon, and get the crank turned down and new rod AND main bearings in it. (I agree with the idea of having the shop that turned it get the bearings for you -- saves ANY confusion.) Worst case it that it will blow and take out the side of your crankcase with it. In between, continuing to run it could chew up the journal on the crank so badly that there may not be enough metal left to turn and polish it, especially if it's been turned down before.
As for the rest of the list, pulling a plug wire to isolate a problem won't help in isolating the bearing. That's more for isolating spark and valve problems.
As for critical stuff, having your head and crankcase hot-tanked and magnafluxed will show up any cracks and their severity. Sounds like it would be worth the cost and effort in your case.
Radiator leaks can often be soldered, though not always. If your water pump is leaking at the shaft and it is put together anything like the pumps on Super As and Super Cs, you'll likely be ahead just replacing it. (Tools, press, language that your preacher might object to . . .) They're reparable, but it can be a bear to do it and do it right.
$$? Leaving those honkin' 38" rears out of the formula, you might figure $1000-$1200 on the motor. And to clarify something I read below(because I had to read it three times) the clutch, throwout bearing and pilot bushing will bear looking at while you've got it apart, and might be another $250-$300, not a whole $1500. (Have the machine shop that turns your crank deal with the pilot bushing while it's there.)
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
