Re: c221-263 swap?
Posted by Ace Schrunk on December 04, 2001 at 04:51:47 from (207.232.79.81):
In Reply to: c221-263 swap? posted by Dann on December 04, 2001 at 01:01:50:
Should be able to change Fly wheel, clutch, the plate that bolts to the back of the block, maybe timing cover, if you sue the 706 manifold you will get a little HP. just what ever is different for mounting
Post A Followup
: Re: Re: c221-263 swap?
