Re: Installing cam bearings
Posted by scotty on December 04, 2001 at 11:32:21 from (199.231.49.128):
In Reply to: Installing cam bearings posted by Zonie on December 04, 2001 at 10:30:36:
Zonie,
Cam bearings are usually installed by an automotive shop with a press and an arbor that
fits the cam bearing bore. Without the proper tools I dont know if you would want to tackle that
project at home. The most important thing is
obviously not to damage those bearings on the
installation.
scotty
Post A Followup
: Re: Re: Installing cam bearings
