Re: Installing cam bearings
Posted by brianh on December 04, 2001 at 12:53:28 from (64.12.103.42):
In Reply to: Installing cam bearings posted by Zonie on December 04, 2001 at 10:30:36:
My shop manual for the M/MD says you can pull them in with a large bolt, nut, and washers to spread the force evenly. It also says you can drive them in with a punch or chisel, with a plate or other device to spread the impact around. I think I'd use the bolt and nut method.
Post A Followup
: Re: Re: Installing cam bearings
