Re: Re: Re: H clutch
Posted by Haas on December 05, 2001 at 05:56:10 from (129.37.117.116):
In Reply to: Re: Re: H clutch posted by speed bump on December 05, 2001 at 04:25:08:
Red suggested greasing the throw out bearing. I assume the H is like the M and also has a fitting for greasing the pilot bearing. You might want to try giving that a shot too. Only needs one or two strokes of the gun,no more than once a year. The fitting is on the outside rim of the flywheel. You have to get under the tractor and turn the engine until the fitting comes to the hole in the bottom of the housing. The fitting is recessed into the flywheel and mine was caked full of that grease/dirt mixture, so was not easy to locate.
Post A Followup
: Re: Re: Re: Re: H clutch
