Re: Re: Gear ratio Super A, 100, 130 etc.
Posted by Hugh MacKay on December 05, 2001 at 13:23:29 from (142.177.60.117):
In Reply to: Re: Gear ratio Super A, 100, 130 etc. posted by scotty on December 05, 2001 at 10:25:33:
scotty: You say in your post that A, B, BN, AV, are all covered in your manual, and are all the same. I thank you for the information. It does not refer to Super A and 130. Those 12.4 tires on my 130 are 5 to 6 inches higher than the 9.5 on my Super A. Hi-idle 130 1650 rpm, Super A 1400 rpm . Low idle is 600 rpm for both. The Super A is miserable to back a trailer with, such hi speed, even at low idle in reverse. As I said in the earlier post these tractors are very close in speed at hi idle. I have calabrated the hi idle speed of these two tractors many times as I do spraying with them. The same spray unit fits both. Same sprayer settings will put same volume on selected areas. Hort crops over the same area several times a year. This is the second Super A and the second 130 I have owned. I dont know the speeds on the earlier ones as I was dairy farming at the time, and they came to me via farm aquisition. I didn't use them much, as I was using big Farmalls at that time. Of the four tractors the current Super A much faster reverse and no.1 foreward.
Post A Followup
: Re: Re: Re: Gear ratio Super A, 100, 130 etc.
