Re: Re: A hard choice, need advice
Posted by Karl F on December 05, 2001 at 21:42:59 from (64.83.223.38):
In Reply to: Re: A hard choice, need advice posted by will on December 05, 2001 at 20:36:47:
if you want to stay away from the lp fuel system, you can scrap/sell/trade those components and go back to the regular gas carbueration system on that same motor. LP engines typically have higher compression, and i think even a non OEM aftermarket setup would have the head modified for more compression.
my dad had an mta until the early 70s that had a shaved LP head on it...she put out 65 horse on the dyno!!!
good luck
-karl
Post A Followup
: Re: Re: Re: A hard choice, need advice
